The Z-probe sets the Z axis of your work zero for you. Easel knows how thick the touch plate is, so it lowers the bit until it touches the plate and then sets Z to the top of your material.
Setting up the Z-probe
Turn on the Z-probe and test it in Easel's computer setup walkthrough. See Adding a Z-Probe to Easel.
Using the Z-probe during a carve
In the carve walkthrough, choose Probe on the Work zero step. Easel walks you through setting up the probe. Each step turns on once you finish the one before it.
- Jog the bit over your material, then click Confirm position (1).
- Plug the lead into the carriage and check the box (2).
- Attach the clip to the collet, then click Clip is attached (3).
- Touch the plate to the bit (4). Easel shows when it detects the connection.
- Place the touch plate on your material, under the bit, then click Touch plate is in place (5).
- Click Start probing (6). The bit lowers slowly until it touches the plate.
When probing finishes, Easel takes you to Confirm work zero. Jog the bit to the front-left corner of your material to set X and Y. Z is already set.
| Important: Always remove the clip and touch plate before you start the carve. |
If the Z-probe isn't working
Check the probe in the Machine Inspector. Open Machine > Machine Inspector and watch Z-Probe Status (1) while you touch the plate to the bit. It should change from No contact to green.
How to read Z-Probe Status (2):
- Green: the probe isn't plugged in, or it's plugged in and the leads are touching.
- Empty circle (No contact): the probe is plugged in but the leads aren't touching.
If the Z-probe step doesn't appear in your carve walkthrough, see Z-Probe step is missing.
