The 3D preview on the right side of Easel shows what your design will look like once it's carved. Check it as you design: anything that doesn't appear in the preview won't be carved.
1. 2D editor
Where you create and edit your design.
2. 3D preview
Shows your design carved into your material, using the material and bit you've chosen. It updates as you design.
3. Simulate
Plays back the path your machine will take. See Toolpath Simulation in Easel.
Fixing areas that won't carve
Missing details usually mean your bit is too big to fit into those parts of the design. In this example, the "Lake Michigan" text is in the 2D editor but doesn't show in the 3D preview (1), because the 1/8" bit is too wide to carve it. After adding a 30° detail bit (3), the text shows up (2).
You can fix this in three ways:
- Use a smaller bit. Choose a smaller bit in the Bit menu.
- Add a detail bit. Click + next to the Bit menu to add a Detail Bit. Easel uses your main bit for the larger areas and the detail bit for the fine details.
- Make the design bigger. Increase the size of the design so your bit can reach every part of it.
| Helpful Tip: Want to see the finished piece in color? See Paint Your Project in the 3D Preview. |
