Home and work zero are two different positions. Home is a fixed point your machine always returns to. Work zero is where your carve starts, and you set it for each piece of material.
Home position
Your machine finds home using its homing switches. It moves the Z axis up first until its switch triggers, then moves X and Y. Because it stops at the switches, home is the same place every time. To home your machine, click the jog button (1) next to Carve… to open Jog Machine, then click Home (2).
If your machine doesn't home correctly, see How to Check Your Homing Switch Status.
Work zero
Work zero is the point where your carve starts. By default it's the front-left corner of your material. Work zero can be the same as home, or somewhere else, depending on where your material is clamped.
Setting work zero
The carve walkthrough guides you through setting work zero:
- Choose Probe (1) or Manual (2).
- Z: with Probe, Easel lowers the bit onto the touch plate and sets Z to the top of your material. Easel knows the thickness of the touch plate, so it sets Z exactly. See Using the Z-Probe. With Manual, lower the bit until it just touches the surface of your material.
- X and Y: on Confirm work zero, jog the bit until it sits right over the front-left corner of your material, then click Use new position (3).
To start your carve from the center of your material instead, see Setting work zero to the center of your material.
Going back to a saved work zero
The Work Zero button in Jog Machine moves your machine back to the last work zero you set. It homes the machine first to make sure the origin is correct. It doesn't set a new work zero.
When you carve the same position again, home your machine and choose Use last position. This works best when your material is clamped in the same spot every time, for example in a jig.
| Helpful Tip: Carving several copies in a row? See Quick Repeat Carving. |
Reading your position
The position readout in Jog Machine shows where the bit is relative to work zero. Once work zero is set, it reads 0, 0, 0 at that point. Negative numbers mean the bit is to the left of or in front of work zero. Home your machine first, or the readout won't be accurate.
If your machine doesn't have homing set up, Jog Machine doesn't show the Home and Work Zero buttons. Instead, it says Homing is not enabled on your machine. To use homing and work zero, set up your machine again.
Machine firmware
Easel supports machines running GRBL, FluidNC and grblHAL (Beta). If you use a FluidNC machine, connection, homing and setup are more reliable in the latest version of Easel. grblHAL support is in beta.
