You can lock and unlock specific shapes in Easel during the design process. Locked shapes will not move, rotate or scale, so you can work on other parts of your design without accidentally changing them.
Locking a shape
- Select the shape you want to lock.
- In the Shape tab, click Lock Object (1).
The button changes to Unlock Object with a blue lock icon (2), so you can tell at a glance that the shape is locked.
Unlocking a shape
Select the locked shape and click Unlock Object (2). You can now move, rotate and scale it again.
| Helpful Tip: If a shape won't move or resize, check the Shape tab. If you see Unlock Object, the shape is locked. |
