Easel users can add a wide variety of materials and bits from a number of different brands and manufacturers to their Toolbox.
Using Custom Bit and Material combinations requires an Easel Pro Subscription
To Add Bits & Materials
1. Once you're logged into Easel, open a project.
2. From the top navigation, click on the Toolbox menu.
3. Select the Bit or Material menu depending on which you want to add.
4. In the top right, you can select the 'Add' button and choose from the manufacturer of your bit or material.
5. If you select any populated bits or materials, you will see the products from the selected manufacturer.
6. If you select Custom bits or materials, you will need to name your custom item and enter appropriate details such as the diameter of the bit or type of material.
7. You can also access the Toolbox from the Material or Bit dropdowns by selecting either "+ Add a Material" or "+ Add a Bit" at the top of each menu.
Materials added to your Toolbox will show automatically in the material dropdown menu when you are choosing your project settings.
*Note: All Toolbox materials currently render as generic tones in the high-definition preview pane. At this time, textures and colors will not match your selected Toolbox materials.*
Related articles:
What bits can I use with Easel?
