With Easel Pro, you can import a 3D model and carve it. You can create relief carves, fully carve out 3D objects, and combine 3D carves with 2.5D workpieces. Easel creates the roughing and finishing toolpaths for you.
For more on 3D in Easel Pro, see FAQs - 3D in Easel Pro and Glossary - 3D in Easel Pro.
1. Import your 3D model
- Click Import (1) in the toolbar and choose 3D STL (2).
- Click Choose File (3) and select your STL file.
- Leave Scale model to fit material (4) checked to fit the model to your material automatically.
Easel opens your model in a new 3D workpiece.
2. Set up your 3D workpiece
1. Material
Enter the size of your material. Make sure it's at least as thick as the part of the model you want to carve.
2. Roughing Bit
The larger bit that clears away most of the material.
3. Finishing Bit
The smaller bit that carves the final surface of your model. See step 5.
4. Model
The position, size, orientation and rotation of your model. See step 3.
5. Cut Style
How the model is carved out of your material. See step 4.
6. Generate toolpaths
Creates the toolpaths for your carve. See step 6.
7. 3D view
Shows your model on your material. You can move and resize the model right here. See step 3.
3. Position your model
Move and size your model right in the 3D view:
- Move it: click the model (1) and drag it, or its relief boundary, into place.
- Resize it: drag a corner handle (2) to make the model bigger or smaller.
- Line it up: as you drag, guides (3) appear and the model snaps into position.
The 3D view shows your design with its cut style, and highlights any part of the model that sticks up above the surface of your material. If you see a highlight, make the model smaller or lower it until it fits.
For exact values, use the Model settings:
- Center to material (1): moves the model to the center of your material.
- Position (2): the X, Y and Z position of the model.
- Size (3): the size of the model. Click Lock XY or Lock XYZ to keep its proportions as you change it.
- Orientation, Rotation and Flip (4): choose which side of the model faces up, rotate it, or flip it.
4. Choose a cut style
Choose a Type (2):
- Full Depth Cutout: cuts the model all the way out of your material. Check Use Tabs (5) to hold it in place, and click Edit to change where the tabs go.
- Rectangle Relief: carves the model into a rectangular pocket. The relief boundary (1) shows the edge of the pocket.
- Model Boundary Relief: carves the model into a pocket that follows its outline.
For the relief styles, set the Cut Depth (3) and the Padding (4), the extra space carved around the model. Rectangle Relief lets you set the padding on each side.
5. Choose your bits and cut settings
For roughing, use a 1/4" or 1/8" end mill. For finishing, we recommend a 1/8" or 1/16" ball nose bit.
- Click the Roughing Bit or Finishing Bit menu (1).
- Choose your bit (2).
- Check the cut settings (3). Easel fills in its default settings for your bit and material, which are a good place to start. See Calculating Your Cut Settings: Basic Feeds and Speeds Information.
- To use the settings other makers use most for this bit and material, click Apply (4).
- For the finishing bit, choose the Raster direction (5): X axis, 45°, Y axis or 135°. Following the grain of the wood gives the smoothest finish.
6. Generate toolpaths and preview your carve
- Click Generate toolpaths. Easel draws the toolpaths on your model (1) and shows the total carve time.
- Click Rough or Finishing (2) to see just that pass, and use the play controls to watch the carve.
- Click Show Preview to see roughly what your finished piece will look like. Click Hide Preview (3) to go back.
| Helpful Tip: Carve time too long? Try a larger roughing bit, a higher step over on the finishing bit, or a smaller model. |
When you're ready, carve the roughing pass and then the finishing pass. See Multi-Stage Carves.
