If you do not have internet access where your machine is housed, you may want to export your project as a G-code file and run it with another G-code sending program. This is possible in Easel with just a few steps.
| Important: You still need internet access to design projects in Easel and export G-code. You will also have to create a Non-GRBL Machine Profile to be able to export G-code. |
Exporting G-code
You can export G-code from your project by clicking Project (1) > Download (2) > Download g-code (3).
If you have a two-stage carve, this will export both the roughing and detail pass as individual .nc files.
This file can then be uploaded to a machine control program of your choosing. You can also preview or edit the file using a text editor.
